liq pipe
Re: liq pipe
You looking for the "Y" pipe or muffler? 76's are different than 77's and 78's.
Re: liq pipe
I know the muffler is real bad but I will have to look at the Y pipe
when i get out to the shop
- 69camaro
- Real Name: Duane Gjerseth
Re: liq pipe
Where do you live in WI? I live near Eau Claire and am only 18 miles from I-94. I am sure I have a pipe and y-pipe if needed off of a 76 Liquifire.
75-340/s
76-340 Liquifire
77-440 Liquifire Custom
78-440 Liquifire
84-Liquifire
84-Sportfire
84-Sprintfire
84-Snowfire
78-Polaris TXL
82-Indy 500
91-XC 400
91-Indy 500 Special
94-Indy 440 Special
95-XCR 440 Special
96-XCR 440 Special
99-XC 600
04-XC 700
81-Kawasaki 440 Invader
76-340 Liquifire
78-440 Liquifire
84-Liquifire
84-Sportfire
84-Sprintfire
84-Snowfire
78-Polaris TXL
82-Indy 500
91-XC 400
91-Indy 500 Special
94-Indy 440 Special
95-XCR 440 Special
96-XCR 440 Special
99-XC 600
04-XC 700
- 69camaro
Re: liq pipe
Also, I am going to Princeton if you want to skip shipping.
75-340/s
76-340 Liquifire
78-440 Liquifire
84-Liquifire
84-Sportfire
84-Sprintfire
84-Snowfire
78-Polaris TXL
82-Indy 500
91-XC 400
91-Indy 500 Special
94-Indy 440 Special
95-XCR 440 Special
96-XCR 440 Special
99-XC 600
04-XC 700
76-340 Liquifire
78-440 Liquifire
84-Liquifire
84-Sportfire
84-Sprintfire
84-Snowfire
78-Polaris TXL
82-Indy 500
91-XC 400
91-Indy 500 Special
94-Indy 440 Special
95-XCR 440 Special
96-XCR 440 Special
99-XC 600
04-XC 700
Re: liq pipe
69 camaro, I live by the big pond between Milwaukee and Sheboygan.
I will be heading to Rice Lake in a few weeks so I will be flying by
right near you, I will look and see if I need the Y and get back to you
soon.
Thanks, yamadeere
soon.
Thanks, yamadeere
- Joliet Jake
Re: liq pipe
Just curious ……….what exactly is the difference between the 76 and 77 liquifire pipes ………
I looked at my 76 and 77 and outside they look the same ………looks like I will learn something new!
72 300
75 LIQUIFIRE
76 LIQUIFIRE
78 LIQUIFIRE
78 CYCLONE
80 TRAILFIRE
81 SRX
83 LIQUIFIRE
83 SPRINTFIRE
88 650 INDY
94 MACH Z
2000 MACH Z
2005 MACH Z
S 35 BONANZA
75 LIQUIFIRE
76 LIQUIFIRE
78 LIQUIFIRE
78 CYCLONE
80 TRAILFIRE
81 SRX
83 LIQUIFIRE
83 SPRINTFIRE
88 650 INDY
94 MACH Z
2000 MACH Z
2005 MACH Z
S 35 BONANZA
- 69camaro
Re: liq pipe
I didn't know there was a difference either. Sounds good Yamaha Deere. My phone # is 715-577-9547
Duane
Duane
75-340/s
76-340 Liquifire
78-440 Liquifire
84-Liquifire
84-Sportfire
84-Sprintfire
84-Snowfire
78-Polaris TXL
82-Indy 500
91-XC 400
91-Indy 500 Special
94-Indy 440 Special
95-XCR 440 Special
96-XCR 440 Special
99-XC 600
04-XC 700
76-340 Liquifire
78-440 Liquifire
84-Liquifire
84-Sportfire
84-Sprintfire
84-Snowfire
78-Polaris TXL
82-Indy 500
91-XC 400
91-Indy 500 Special
94-Indy 440 Special
95-XCR 440 Special
96-XCR 440 Special
99-XC 600
04-XC 700
Re: liq pipe
[quote="Joliet Jake"]Just curious ……….what exactly is the difference between the 76 and 77 liquifire pipes ………
I think you might be right about Liquifires but I was thinking there was difference in Y pipes between 76 and 77 Cyclones.
Re: liq pipe
My best guess would be the internal tuning is different to reflect the change in '77 to regular grade gas and a slightly less compression ratio.69camaro wrote:I didn't know there was a difference either. Sounds good Yamaha Deere. My phone # is 715-577-9547
Duane
Re: liq pipe
Hi Guy,
I know the Y pipe changed for the 77-78 440 Liquifires. The 76 unit fit both the 340 and 440 that year, and was also used on the 77-78 340 LF's. Don is correct, the Cyclone Y pipe and muffer and different than the LF units. Not sure if the LF pipe changed or not, but I have parts book here I can check...
Re: liq pipe
I looked in the parts book for the Cyclone Y pipe number guessing that -70000 was different than 70000- but it showed AM 53987 for both just further confusing me!!
- Joliet Jake
Re: liq pipe
AHHHHHH……… the sweet mysteries of life just go on and on!…………
.I think 76 and 77 Liquifires are the same ……..but I always try to keep up of such things………as you all know it’s not uncommon to find a little swapping going on either at the factory or sellers shop!
72 300
75 LIQUIFIRE
76 LIQUIFIRE
78 LIQUIFIRE
78 CYCLONE
80 TRAILFIRE
81 SRX
83 LIQUIFIRE
83 SPRINTFIRE
88 650 INDY
94 MACH Z
2000 MACH Z
2005 MACH Z
S 35 BONANZA
75 LIQUIFIRE
76 LIQUIFIRE
78 LIQUIFIRE
78 CYCLONE
80 TRAILFIRE
81 SRX
83 LIQUIFIRE
83 SPRINTFIRE
88 650 INDY
94 MACH Z
2000 MACH Z
2005 MACH Z
S 35 BONANZA
Re: liq pipe
If I remember correctly, there was a high performance pipe available for the 440. It added a couple more horsepower. The way to tell the difference is the normal pipe, when installed, comes to around the front of the chaincase cover, while the hp version is appox. 6, 7 inches longer in the body, coming to just about the end of the chaincase cover. Correct me if I'm wrong.
Bob
Bob
