1979 John deere Trialfire 340 Problem
I'm having trouble with my trailfire. it started with quick start down the carb, But wont stay running. It has good spark, over 120 compression in both cylinders. So is it my fuel pump or something else?
Dillon Devine
Chatham ON
2 1979 John Deere Trailfire 340's. Also have seized 340 and 440 (later to be rebuilt)
1990 ski-doo safari (Dad's Sled)
Chatham ON
- Liquifire84
Re: 1979 John deere Trialfire 340 Problem
When was the last time to took the carb appart and cleaned it all up? I would start here first myself they check for fuel pump, filter, and lines/
well i tryed a different pump. it got the gas in the line but it wont go to carb. It putts but wont start fully. i took carb apart and the bowl had gas in it. but i took bottom off, and the needle in the jet under that gold float dropped on the ground. its the one that has a pin that goes through it. would that cause it as well? ![Wall :wall:](./images/smilies/eusa_wall.gif)
Dillon Devine
Chatham ON
Chatham ON
- johnnycyclone
- Real Name: Terre
I would pull the carb off, disassemble, clean, inspect and then reassemble per specifications in the manual. You want to make sure all the passages are clear, and that all the parts are accounted for. I bought a Traifire 2 years ago that would load up all the time. I found out after taking the carb apart that it didn't have a pilot jet in it. I would also buy a rebuild kit for fuel pump and do a rebuild on the fuel pump. Other wise you might be chasing your tail all winter.
I would make sure the crank seals are good and the line that goes from the crankcase to the fuel pump isn't cranked and in good shape.
well i'll see tomorrow when i get the new needle valve and float arm pin.
Dillon Devine
Chatham ON
Chatham ON
- 80spitfire
- Real Name: Brian Kottke
I second replacing the impulse line from the crank to the carb cuz that can definitely keep it from pumping gas right.
72' 500 Restored
74' 295/S Unrestored
75' 340/S Rider
76' Liquidator Restored
77' Liquifire Rider
80' Spitfire Restored
75' 340/S Rider
77' Liquifire Rider
another consideration nwould be crank seals , bad seals can cause all kinds of goofy runability issues . getting these items renewed /replaced will give you a great foundation to begin to fine tune your machine
well i almost had it started. it sucks gas up to half of the line to the carb. i sprayed gas into the carb several times and it almost fired up. But wont actually start.
Dillon Devine
Chatham ON
Chatham ON
You surely have a blown crank seal bud. You gotta get them changed out before you distroy that engine. it will only set you back about $10 and it will onl take a few hours. The crank seals are also a major factor in fuel pump performance. Hope this helps.
DE
DE
What Dustin said!
but would that explain it will still not start with spraying gas into carb? it will putt sometimes, it will almost start sometimes. and sometimes you can hear a burst of air sometimes when it putts
Dillon Devine
Chatham ON
Chatham ON
- Real Name: Lloyd
yep it would.
Blown crank seals got let the cylinder pull the fuel up into the combustion chamber.
get them changed.
Lloyd
get them changed.
Lloyd
Several Deere's
Several Kawasaki's
ACSCC #1534
Several Kawasaki's
ACSCC #1534
What DA said. and every one else.
Crank seals need to be renewed.
so when i get new crank seals in. it will run?
Dillon Devine
Chatham ON
Chatham ON
