1979 John deere Trialfire 340 Problem
JD600
Re: 1979 John deere Trialfire 340 Problem
Post by JD600 »
There are a lot more variables to consider.
What is the compression? Is it equal between the cylinders? Has the carb been cleaned? Is the fuel pump in good shape internally? There are so many things that can cause one of these things to not want to start, all you can do is go through your service manual and eliminate all of the posible issues. Best of luck, and we'll be here to help.
DE
JDFanatic19
Post by JDFanatic19 »
the compression is 120 on both cylinders, fuel pump works good, and carb is clean. i don't have a service manual
Dillon Devine
Chatham ON
2 1979 John Deere Trailfire 340's. Also have seized 340 and 440 (later to be rebuilt)
1990 ski-doo safari (Dad's Sled)
JD600
Post by JD600 »
If thats all ture, it should run! :) Once you get those seals changed, it should be in good shape. Keep us posted.
DE
JDFanatic19
ok np will do!
Dillon Devine
Chatham ON
johnnycyclone
Real Name: Terre
Post by johnnycyclone »
You can find a service manual at:
vintagesnow.com
JDFanatic19
Thanx, i know the site your talking about well
Dillon Devine
Chatham ON
