http://www.parkeryamaha.com/mikunifuelp ... dual1.aspx
I trying to install one of these in my 80 liquifire. Anybody provide any knowledge on hooking one up. I have vacuum going to port on top. 4 oclock barb left carb (pto) and 7 oclock to right carb (mag side) fuel going into 10 oclock barb. Is there a trick maybe to priming a liquifire carb system? I don't have the air box on and the carb are clean. This must be a mod somebody has done right ?
DF52-73
- I500
- Real Name: Chuck Moser
Re: DF52-73
Did the line in the gas tank become disconnected and now its just sucking in air and not fuel..... Been thru that once or twice
- JDXspec
- Real Name: Dustin
Re: DF52-73
Normally there are arrows on the other side showing fuel direction. Like I500 said, you have fuel to the pump?
Re: DF52-73
I'll try filling the tank fuller. Im at about a 1/4-1/3 full. I'll see what happens. Other than that, you think the thing is hooked up right? I did not see any arrows that gave any clues. BTW it is a Mikuni.
Re: DF52-73
Should be like this:
DSC_7748 (Medium) by nick80lf, on Flickr
The line from the tank connects to the barb without a hose. The 2 that point up go to the carbs. If adding more fuel doesn't work; do you have a vacuum leak (bad impulse hose, crank seals, ect.)?
Re: DF52-73
Try switching the impulse and tank lines around.
In the photo on the parts page link you suppiled the pump is shown upside down.
