Well the other day my Dator crank finally made it back in one piece and I must say it looks fantastic! Jerome does such good work! I'm getting really close to having the motor all ready to be put back together. The cylinder and head are at the machine shop awaiting machine work and once I get them back I'll paint them up and put the motor back together.
I found some very interesting things when I was working on that motor
The first thing being one grooved piston and one smooth piston. The smooth piston ended up snagging a ring and damaging the combustion chamber. This all happened around 20 years ago.
Another thing I found was the thermostat,the one that was in it had the pin blown through the top of it. I'm not quite sure how that one happened. I put a picture of it next to a NOS one so you can see the difference.
When I was taking off the intake boots I found something interesting there too. Somehow one of the studs went missing at some point and someone decided to just put a bolt with a bunch of lock washers instead
it was pretty loose when I took the boots off too. I'm not sure if that was the side that the bad piston was one but it wouldn't surprise me if it was. I'll have to check when I get the cylinder back.
But anyways, it's been a pretty interesting engine so far.
