340/5 cylinders.
340/5 cylinders.
I need a good useable set of 340/5 cylinders. Need to be standard bore.
Kurt.
295/s
'72 400, Modern suspension, mod 440/5, hoping to be 65hp
'91 Eagle Talon 10.9@140, street tire E85 3400lbs.
295/s
Re: 340/5 cylinders.
i have a pair on a motor , assume they are std ,id trade for other piston port stuff or whatever ?
I have a set of regular kec340 cylinders on a running motor. I also have a complete 25mm crankshaft KEC340. Basically I'm trying to put together a 340/5 that I'm going to port for 8000rpm to put in my 295/s until we can get some pistons sorted out. I have a running 30mm crankshaft KEC340 in it, and I want to swap on the 340/5 cylinders, and the rest of the 295/s stuff.
I also have a 440/22 thats locked up
Kurt.
295/s
295/s
