Ahh! Stripped spark plug on CCW 340 head! (looking for head)
Grrr, I was putting a spark plug back in tonight and I guess I tightened it a little too tight on the clutch side head. Not as tight as I would on anything else since I can tell it doesn't seat as firm as my newer stuff but it still stripped.
I am hoping somebody here can help me out that may have a parts sled or something like that. It's a 1974 400 with a CCW KEC 340. The left (clutch) side head.
BTW: First post, this site has been amazing so far for finding all the info I've needed.
1974 JD 400
Re: Ahh! Stripped spark plug on CCW 340 head! (looking for h
is there any way you could put a thread insert in it , i rescently took a 340/s intake to my machine shop buddy that had a broken shroud bolt in it . someone had drilled it out kinda crooked and crammed a sheet meatl screw in it .he drilled it out and installed a larger thread insert in it and salvaged the part . just a thought wade
- Real Name: John
Hi there u can try a helicoil .It comes with the tap and helicoil . If not I have abought 40 some jd parts sleds and A shed full of nos parts.Hopefully this will help John
72 400/500
73 500 one Dad bought new
74 300/295s
75 800/340s
76 340 LIq
78 Liq 340/cc/Spitfire
80 Liq/Sport
81 Liq
82 Liq/Sport/Sprint/Snow/Spit,
83 Liq/Sport/Trail/Sprint/Snow
84 Liqx3/Sportx3/Trailx3/Sprintx3/Snowx2
74 300/295s
75 800/340s
76 340 LIq
80 Liq/Sport
81 Liq
I've checked out helicoils and they can be pretty expensive, like $100 so I'd like to stay away from that route if I can find a good head to replace it with.
That would be awesome if you could find me one in your stash, john! I can get you the JD part number if that helps or whatever you need.
1974 JD 400
you are right ,a new head would be the best fix for sure , i wouldnt reccomend a helicoil necessarily , but a much thicker thread insert would work too , you wouldnt have to buy their tap also and can be purchased through mcmaster carr or msc and they are realatively inexpensive ,wade
I believe such an insert as lwb is referring to is called a keensert (sp?). However you need to be sure that you know the correct threads per inch and the thread pitch of the spark plug threads. Also if you were to drill out and put in an insert be very careful that the insert does not protrude through the bottom of the head. I would recommend just finding a different head.
Adam Epp
Winnipeg, MB, Canada
74 400 (2 - sold)
74 400 (2 - sold)
- Real Name: Jerry Zebro
I have one you can have Just pay shipping. What motor is this KEC 340 or a 340/5?
Jerry
Jerry
It's a 340/5. Hopefully it's what you have and will work...
1974 JD 400
Yes I have have some of each, get me your Address and I will get it in the mail Friday. Clutch side Head for 340/5 .
Jerry
Jerry
Yes, clutch side head. Very cool! You have a PM.
1974 JD 400
Got It.
Jerry
Jerry
I purchased a spark plug thred chaser years ago from Leslie at the local AutoParts store.
It is duel ended for both 14 and 18 MM. Cost was $15.
I chased the heads on every sled I do.
Never use a plug with questional threds!
