77 liquifire tach no functioning properly
just installed a new tach on my sled, plugged it in, put the ground on and it seems to have some life only problem is when its idling it just goes right to 8000 and stays there...as high as it goes.
anyone had this issue before?
77 john deere 300
77 john deere liquifire 340
- 80spitfire
- Real Name: Brian Kottke
Re: 77 liquifire tach no functioning properly
Are you sure y have the right tach? The earlier sleds with a Prestolite ignition require the older style tach with a fuse on it. The newer sleds tach do not have the fuse. I'm just wondering if possibly you have a tach for a later sled and that's why it's not working.
Brian
Brian
72' 500 Restored
74' 295/S Unrestored
75' 340/S Rider
76' Liquidator Restored
77' Liquifire Rider
80' Spitfire Restored
75' 340/S Rider
77' Liquifire Rider
i see....
i bought it off the interenet, came with instructions and how to install it on fire series sleds along with earlier 70's sleds as well...
which type of ignition does a 77 liquifire 340 have?
77 john deere 300
Sorry to say but you bought the wrong tach for your '77 340 Liq. As 80spitfire stated, the correct tach will have a inline fuse. That style tach was used on all the Kioritz engines that had cdi ignition from 75 thru 78.johndeerejamie wrote:i see....
- 80spitfire
Shoot I was hoping I wasn't right for your sake lol As far as for getting the right tach, I think you're probably best off just getting a used one of of ebay because those tachs have become very difficult to find in NOS.
Brian
Brian
72' 500 Restored
75' 340/S Rider
77' Liquifire Rider
75' 340/S Rider
77' Liquifire Rider
oh ok, it was only 10 bucks so its not the end of the world. if i put an inline fuse in, will it work?
also will the one i bought work in a 77 300?
77 john deere 300
nope sorry they will work on the point type ignitons on the ccw 72 -75 sleds and the kawi powered 80-84 sleds wadejohndeerejamie wrote:oh ok, it was only 10 bucks so its not the end of the world. if i put an inline fuse in, will it work?
Wade is correct. The tach runs off the lighting coil, the points ignition sleds, and the Kawi powered ones both use a "shoe" type coil. The Kioritz powered sleds with CDI ignition use a circular muti-pole stator. The tach counts the impulses, so the two types require different tachs.
hmm i ssee, thanks guys!
so the 300 and kioritz 340 use the same tachs?
77 john deere 300
johndeerejamie,400brian wrote:Wade is correct. The tach runs off the lighting coil, the points ignition sleds, and the Kawi powered ones both use a "shoe" type coil. The Kioritz powered sleds with CDI ignition use a circular muti-pole stator. The tach counts the impulses, so the two types require different tachs.
As Brian stated, the tach that you bought will only work with the early CCW and later Kioritz engines with POINTS and the later Kawi powered FIRE-SERIES for the reasons stated above.
The Kioritz engine that you have (KEC 340/LC) requires a different tach since it has a cdi ignition system. The external inline fuse is an "indicator" as to the type of tach it is. They are wired differently internally.
Last edited by harleysportster on Sun Dec 18, 2011 10:14 am, edited 1 time in total.
Are you referring to the early CCW 340 with points?johndeerejamie wrote:hmm i ssee, thanks guys!
