Where would the VIN number be on a Cyclone 440?
flattracker23
Post by flattracker23 »
I just got a Cyclone 440 and want to know where I would find the VIN number on it so I can see what year it is.
Spencer
1975 800
1976 Cyclone 440
1977 Cyclone 440
1980 Liquifire 440 x2
1980 Trailfire 340
1980 Trailfire 440
1981 Sportfire 440 x2
1982 Sportfire 440 x2
kwc
Real Name: Kevin Campbell
Re: Where would the VIN number be on a Cyclone 440?
Post by kwc »
right side of the tunnel.
Kevin Campbell
Vicksburg, Michigan
Kevin is right on, it should be down by where your right foot would sit.
Just in case you don't have the s/n breakdown:
50,001- 1976 Mean Green, steel skid, refective Deere on side of hood
70,001- 1977 same appearance, no reflective Deere sticker on side of hood, reduced mass, more alumium underhood
80,001- 1978 Bright Emerald Green, aluminum skid frame.
I hope this helps,
-Joe Rainville
flattracker23
kwc wrote:right side of the tunnel.
I know that is where it should be but there is not a plate on the right side of the tunnel. Would it be anywhere else?
Spencer
1975 800
1976 Cyclone 440
1977 Cyclone 440
1980 Trailfire 340
1980 Trailfire 440
Sprailfire340
Post by Sprailfire340 »
More than likely it was removed or painted over. You may be able to see the indentation of the original stamping on the inside of the tunnel. Another possibility is it was a replacement tunnel that was not stamped as required after it was installed.
:sled: ME
JoeRainville wrote:Kevin is right on, it should be down by where your right foot would sit.
I hope this helps,
-Joe Rainville
Joe hit all the indicators except the lower portion of the coil mount on the 76 cyclone bolts between the carb and spacer. The 77/78 mount above the carb.
With all the info given, you can easily determine the year by the looks of the sled.
lwb140
Real Name: Wade bennett
Post by lwb140 »
one quick indicater i use is the 76s have the reinforcement ribs on the side of the pan above the spindle , just something that helps me . wade
lwb140 wrote:one quick indicater i use is the 76s have the reinforcement ribs on the side of the pan above the spindle , just something that helps me . wade
Like he said....
liquitisplit80
Real Name: Roy
Post by liquitisplit80 »
This thread caught my interest because I have a '78 spitfire that doesn't have a vin # or the Canada certification sticker either. It's not painted over, ground out or worn off, it just doesn't have either of 'em. Never thought about the tunnel being replaced.
'78 Spitfire
82 Trailfire 340
'80 Trailfire 440
'80 sportfire
'81 liquifire
Still ridin' the New Breed!
If there is no VIN number in the tunnel, it's most likely a replacement unit. When I started to restore my 340/s a few years ago, Lindner asked me what my serial number was. Turned out it didn't have one. I ended up trading to another collector who likes that for one with a serial number so it would be easier to register once restored.
-Rainville
flattracker23
I found the VIN number and it is a 1976. Thanks for all the replies.
Spencer
1975 800
1976 Cyclone 440
1977 Cyclone 440
1980 Trailfire 340
1980 Trailfire 440
