80 l/f idler wheels and brackets needed
hello all , im needing a couple sets of front idler wheels and mounts for an 80 lf, the little dudes that bolt between the rails can get part numbers if needed but need the mounts, shaft spacers and hardware all that bolys on with the allen head bolts thanks wade
Re: 80 l/f idler wheels and brackets needed
Wade, IF you can't find any we can rob some off some of those 80 Liquifires we have up north..
thanks kenny , !! hope i can find a set or two and not have to wrench too much when we get up there ,lets hope it snows wade
Wade, I have the brackets that bolt to the slide rail. At least the aluminum part. The rest can be made in a machine shop after purchasing the idler wheels. Let me know if you need the brackets.
After thinking about it, I might know where there is at least one complete set but I'm not sure if the owner will part with just that item as he wants to sell the entire suspension. Let me check.
da , i could use the aluminum brackets for sure , ive got one set that were way overtightened and the brackets is a mess , im interested in any or all , thanks and let me know wade
I'm checking.
thx
Wade you have a PM.
