1983 Liquifire electric start help
I was fortunate enough to pick up an 83 Liquifire parts sled that has an electric start. Do any of you have a electrical schematic that you could post for me and/or give me some insight on installing it on my 83 resto project?
Thank you in advance!
Sean
Sean
- Liquifire84
Re: 1983 Liquifire electric start help
Its in the tech manuals if you have them. If not I can scan and email it once I go back to work in a couple of weeks.
Brice
Brice
- Hackinator
Here is a schematic from the 1980 Kawasaki LTD tech manual. Should help as a reference.
- Hackinator
And here is all the insight that you need into doing it on a John Deere. http://www.vintagesnow.com/John_Deere_f ... tricStart/
Lucky for Sean that he won't have to go through the process of making his own hole since its an 83. That right there looks like a lot of workHackinator wrote:And here is all the insight that you need into doing it on a John Deere. http://www.vintagesnow.com/John_Deere_f ... tricStart/
DE
You're right Dustin!! Worst case scenerio here is removing two bolts that hold starter cover in place.JD600 wrote:Lucky for Sean that he won't have to go through the process of making his own hole since its an 83. That right there looks like a lot of workHackinator wrote:And here is all the insight that you need into doing it on a John Deere. http://www.vintagesnow.com/John_Deere_f ... tricStart/
DE
- Hackinator
That is good news. The reason I have never put an electric start on my '80 is because I have no desire to go drilling holes in the crank case. I've learned something new today. Was '83 the first year that it was a cover plate?
I believe it was about half way through the 82 model year that it changed. Sean, where is tha battery box on that thing? I can't figure out where they would put it.
DE
DE
The battery box mounts in front of the clutch on the lip of the left TPR panel.
Thank you everyone for all the help.
Sean decided that we could install the starter at a later date in an effort to get this thing running and ready for a ride in mid-January. After watching him pull the cord tonight numerous times......he might change his mind again.
- Hackinator
Must have excellent compression... In any case here are some images from a parts catalog that show a diagram and the corresponding parts list that may be of use when assembling and installing an electric starter kit into a Liquifire. Best of luck. Maybe once you get it installed, it will snow.
Hack,Hackinator wrote:That is good news. The reason I have never put an electric start on my '80 is because I have no desire to go drilling holes in the crank case. I've learned something new today. Was '83 the first year that it was a cover plate?
FYI, if you need to cut the hole, the flywheel most likely will not have the ring gear.
