Well after determining that I need to replace crank seals and clean the carb, I thought I might as well clean this thing up a bit.
First thing i did was take off the chain case cause it was leaking, get it off and what do you know theres half of a gaskit and a o ring that is in many peices . With that off it gave me easy access to the air box bolt so that came off next( I now see why you guys say to put the short style carb boots on these things cause it took a while to get out). I then went to the front and took of the hood and the mufler. Now I'm down to the engine, clutch, and the battery box.
Things I have already found that need replaced or repaired other than crank seals are: TPR panel, throtle block, chain case o ring and gaskit, tie rod ends, the grill, the bumper, seat, and backrest.
More to come as I dig deeper into this one
Clay
Trailfire 440 clean up
Clay Gerfen
My Sleds
1 1978 Spitfire
1 1979 Spitfire
My Sleds
1 1978 Spitfire
1 1979 Spitfire
- liquitisplit80
- Real Name: Roy
Re: Trailfire 440 clean up
What year is that sled? I have an '80 440 but it has '79 decals both on the hood and tunnel. Strange! Thats the way I bought it. Dont know if it originally came that way or not but its a little irritating knowing its not right. Dont want to start 'fixing' things 'cause I know I wont stop with just the decals once I start! LOL! Good luck with your project and keep us posted!
'78 Spitfire
82 Trailfire 340
'80 Trailfire 440
'80 sportfire
'81 liquifire
Still ridin' the New Breed!
82 Trailfire 340
'80 Trailfire 440
'80 sportfire
'81 liquifire
Well its been awhile since I updated this. Here are some things that I have added or fixed: cleaned carb, new belt over seat, a suspension shock of the front of a yami 4-wheeler for the suspension, and a chain tensioner that i made my self.
Clay
Clay
Clay Gerfen
My Sleds
1 1978 Spitfire
1 1979 Spitfire
My Sleds
1 1978 Spitfire
1 1979 Spitfire
Clay,
That chain looks a bit snug. You might want to check the Liquifire book to see where it is supposed to be set.
