Aftermarket Cyclone Tach
ski
Post by ski »
I just hooked up a modern Polaris (two pulse) tach on my 78 Cyclone. It has a large face and I don't know the exact year. But, it read high at idle around 5000 rpm. So obviously it is not right. I'm wondering if a 4 pulse,6 pulse, 9 pulse???? Whatever pulse?? will work. Wired it into lighting circuit. Yellow and tan(brown?) wires I believe.
Anyone try this on their Cyclone and get it to read properly?
Re: Aftermarket Cyclone Tach
Good used OEM tachs show up on Ebay now and then.
you need a 6 pulse to read correctly on your CCW.
TASKY
Post by TASKY »
On a side note. I am wondering how do you tell what tach is what pulse?
80spitfire
Real Name: Brian Kottke
Post by 80spitfire »
I would have a good working OEM tach if you're interested.
-Brian
72' 500 Restored
74' 295/S Unrestored
75' 340/S Rider
76' Liquidator Restored
77' Liquifire Rider
80' Spitfire Restored
I have seen some tachs that are marked on the back 2,4 or 6 pole or pulse.
If you were looking at a new aftermarket unit then it would be on the box for sure.
Otherwise you would need to look at a wiring diagram of the stator on the engine that the tach came from.
ski
Post by ski »
Thanks for the help guys. The correct tach for my 340 Kioritz engine is a 6 pulse. A found a late model large face Bombardier tach that works great now. And as a bonus it has large enough numbers that I can read and it's lighted too!. This is a racing application so it didn't have to fit in original hole. Also.. the pulse number was ink printed on the back of the tach.
johnnycyclone
Real Name: Terre
Post by johnnycyclone »
Don't forget ski, we like pictures!
ski
Post by ski »
I got to try and figure that out...the picture posting that is!
johnnycyclone
Real Name: Terre
The key to posting pics is the file size can't be over 200K. I use a free online picture resizer on all of my pics before posting, here is the link:
http://www.picresize.com/
If you have trouble and want to give up go ahead and send them to terreb@umich.edu and I can post them for you....Terre
ski
Post by ski »
A 4 pole or pulse won't work either on the CCW/Kioritz CDI engines, I found that out on Tuckers 295/S..
I have NOS 10,000 RPM Sun Sno-Tachs 4 or 6 Pole/Pulse & NOS 8,000 & 10,000 RPM Arrow Tachs 4 & 6 Pole/Pulse.. All $100.00 ea. + shipping
