Before I dive in......
- Danzig
- Real Name: Paul File
The old stator bolt that was stripped out was extracted, points then set to .014 and the timing set to .023 before TDC. She runs, ok. I guess. She still needs choked whether hot or cold?? 2 new B9ES plugs also were installed. Gotta get some snow now and see what I have. Thanks guys!! I hope someone learned from this endeavor besides me!! I am still not sold on this yet.........but let it snow and we shall see.
- Danzig
I forgot to add...........I need a beer!!
- Danzig
I set the points first, both sets. They both read .014 wide open.
I thought you had the engine running without all the choke useage once?
1-2" of snow here last night. Too early to suit me!
- Danzig
I did it exactly as you have it listed Rich.TakeItToTheLimit wrote: Paul...I think something is misunderstood...to simplify:
1. Adjust the points for both #1 & #2
2. Set stator to correct timing of #1 cylinder (dial indicator in #1 head)
3. Reset points on #2 to correct timing (dial indicator in #2 head)
-RICH
- Danzig
The no choke was required with the low idle mix backed out 5 turns. I have the carb now as close to the manual as it can get.400brian wrote: I thought you had the engine running without all the choke useage once?
The choke is pulled out, pull the rope, engines starts and runs as if its loaded up, then I quickly push the choke in and she runs. This is on a hot or cold startup up.
- Danzig
Well today the X8 is sporting some new blitz black throughout!! Rich.....TITTL...... I had to go with the gloss black on the skis...........sorry.
The sled looks awesome.
