CCW 400 Compression
SHOOT DEERE IT IS
CCW 400 Compression
Post by SHOOT DEERE IT IS »
I have a 71 Skiroule with a CCW 400 in it. How much compressions should it have. My tester shows over 200 per side. Sounds a little high to me.
dap574
Re: CCW 400 Compression
Post by dap574 »
Maybe some one put 340 heads on it? 200 psi is a lot.
good luck, Dave
JD600
Post by JD600 »
have the cylinders been oiled? I've seen 190's before if the rings were just oiled. Once it runs, it will loosen up a bit.
The CCW 400 runs very high compression.
I have tested them up to 215 psi without oil.
The 340/440 are not like this , only the 400.
You must use premiem fuel in this engine.
And hold on tight to the recoil ....and the handlebars.
snowcrazy
Post by snowcrazy »
Hey Guys!
I have a JD 400 w/167 psi per side. It has only 950 miles on it. :beers;
