Well after determining that I need to replace crank seals and clean the carb, I thought I might as well clean this thing up a bit.
First thing i did was take off the chain case cause it was leaking, get it off and what do you know theres half of a gaskit and a o ring that is in many peices
. With that off it gave me easy access to the air box bolt so that came off next( I now see why you guys say to put the short style carb boots on these things cause it took a while to get out). I then went to the front and took of the hood and the mufler. Now I'm down to the engine, clutch, and the battery box.
Things I have already found that need replaced or repaired other than crank seals are: TPR panel, throtle block, chain case o ring and gaskit, tie rod ends, the grill, the bumper, seat, and backrest.
More to come as I dig deeper into this one
Clay
