lighting on jd 300
lighting on jd 300
Hi & great site. I own a 72 292 lynx & a 74 jd 300.Finally got the 300 running. My bulbs were burnt out,Dimmer switch shot. I was not getting any power to my headlight. What i did was run a hot wire from my dash into the headlight ,which now works.Problem is it idles nice untill i turn on the headlight.When i do this the rpms jump up & down.Never had a problem like this,Could it be from the dimmer switch,I did switch my headlight connector from 3 prong ,to two & now run a high beam only headlight. Also have new rings,Would this problem change as the rings seat,{havent been able to break them in yet. thanks
lighting on jd 300
the headlight shouldant affact anything in the engine unless it is calling for mor power to power the bulb. Like a car it ideals smooth untill yo turn the ac on and it senses it and makes it idel faster thats the only reason i can think of your asking too much because the wire run from the das it isnt used to have to power a headlight. Also do all your other bulbs work. Just a thought could be completly wrong.
Bob
Bob
lighting on jd 300
Thanks for the reply. I think your right,Its a high beam light.Ill try a low beam if i can find one.I couldnt see paying the $40.00 for the right headlight when my dimmer is frooze up.The headlight i used is likely a tractor light which doesnt show the watt.s . I think ill have this ole 300 in good shape now if i could get the drive belt aligned without the jd tool they recommend to use. thanks.
lighting on jd 300
If you go to the home page of this site, you will find a wiring diagram for 00 series sleds ( under tech ? ). Perhaps you should take a look, and see where and what you have connected the lights to?
lighting on jd 300
Hooked up the yellow wire from my dimmer switch,To the pink head light.Ill try a low beam headlight.
lighting on jd 300
$40.00 for a headlight? they sell them at Autozone for $8.00. I've been using
GE 5006 bulbs and they work fine
lighting on jd 300
Rich you are always such a wealth of knowledge......I remember just last yr explaining on the board how you can use the the type of bulb blitzblack is talking about instead of the $25-30 type parts suppliers are selling. I use the halogen type in fact at about $6. Your explination really puts it all in perspective!!!!!!!!
