build numbers ?
build numbers ?
looking for build numbers on the different types of 1979 trilfire 440's have a chance to get a trailfire and do a restore on it but would like the build numbers on the different models of trailfire 440's this one i was told was a base model with no speedo or tach any help just trying to see how rare the sled is by build numbers
Re: build numbers ?
From the http://www.jdsleds.com home page, build numbers can be found on the left-hand side under Menu > JD Models.
http://www.jdsleds.com/models/models.html
Re: build numbers ?
The tach and speedo were often dealer installed options so there is no actual known amount of how many sleds were sold with each option.
DE
DE
Re: build numbers ?
thanks for all the help you jd guys are great i didnt know that the options were put on at dealer but good to know
Re: build numbers ?
79 T-fires had a steel tunnel.
Therefore beware the tinworm.
Look under the seat to see if there is anything there.
Also check around the foot holds and bulkhead for rust or daylight.
Re: build numbers ?
is there anything else i should be aware of when getting this 79 t-fire just dont want to run into something that i wouldnt know to look for on this sled all your help is appreciated and if i can help on anything feel free to ask.
thanks,
backyard bob
thanks,
backyard bob
