build numbers ?
codebluemi
build numbers ?
Post by codebluemi »
looking for build numbers on the different types of 1979 trilfire 440's have a chance to get a trailfire and do a restore on it but would like the build numbers on the different models of trailfire 440's this one i was told was a base model with no speedo or tach any help just trying to see how rare the sled is by build numbers
RLFollman
Re: build numbers ?
Post by RLFollman »
From the http://www.jdsleds.com home page, build numbers can be found on the left-hand side under Menu > JD Models.
http://www.jdsleds.com/models/models.html
JD600
Re: build numbers ?
Post by JD600 »
The tach and speedo were often dealer installed options so there is no actual known amount of how many sleds were sold with each option.
codebluemi
Re: build numbers ?
thanks for all the help you jd guys are great i didnt know that the options were put on at dealer but good to know
Re: build numbers ?
79 T-fires had a steel tunnel.
Therefore beware the tinworm.
Look under the seat to see if there is anything there.
Also check around the foot holds and bulkhead for rust or daylight.
codebluemi
Re: build numbers ?
is there anything else i should be aware of when getting this 79 t-fire just dont want to run into something that i wouldnt know to look for on this sled all your help is appreciated and if i can help on anything feel free to ask.
thanks,
backyard bob
