JDM-104 & JDM-41-5 & M66939x
Trying to identify a couple tools that don't appear to ever have been used and some other part. Anyone know specifically what they're used for?
JDM-104
JDM-41-5
M66939x
JDM-104
JDM-41-5
M66939x
Re: JDM-104 & JDM-41-5 & M66939x
Randy, those tools are of no value. Suggest they be sent to Indiana for further examination.
- Sprailfire340
JDM-104 is a Flywheel Holding Tool for the Kohler Spitfires
I'm not sure what JDM-41-5 is, but sequencially it follows the service kit JDM-1-C which is listed in SM-2100
JDM-41-1 Clutch Puller
JDM-41-2 Screw Assembly, Swivel and Ring
JDM-41-3 Spider Tool
JDM-41-4 Two-Piece Nut
JDM-42 Clutch Pulley Aligner
JDM-43 Flyweight Retaining Tool
ME
You're on a roll Mitch... don't stop there. Unless the JDM-104 also works on a Kawasaki Spitfire, I don't need it.
Thank you everyone for the info below, much appreciated. Looks like none will be of any use for my sleds.
JDM-41-5 - The square block with the pin is to use on a Comet 100 Series Clutch...you install the tool for the spider removal, then install this block & put the block in a vice. Then, using a breaker bar, loosen or tighten the spider.
M66939x - The curved piece of flat steel is intended to be welded on the front of the '74 - '76 suspension rail when installing the 2/3 track; it replaces the small round rod.
Interested in the 41-5.
- Real Name: Ed Jones
I would be interested in the JD-104 seeing how I have 5 of them it would be very helpful.
Nothing Runs Like A Deere
What? Nobody wants the piece of bent iron???
Randy, How much for the bent piece of Iron shipped to 64014, I have one I might as well have 2 right?
Kenny --- it's on the way.
cledussnow77 --- the JD-104 is yours if you want it. PM sent.
Randy
Randy
