Chain case oil
yzboy99
Chain case oil
Post by yzboy99 »
Anyone heard of using ATF in their chaincase? I had someone tell me they were running it in their 2000ish Catfish, because it is used in most 4wd transfer cases, and that is all that is in there: chain and sprockets.....hmmm.
Chain case oil
Lighter oil such as ATF or synthetic would be better for easier lubrication in extreme cold BUT remember that after all these years the lighter oils may leak out thought the gasket, "O"-ring or even the bearing, I have even seen light weight oils leak out between the shaft & the bearing. If you use ATF or a synthetic just watch for an oil puddle under the chain case.
Ken
JRC ETD
Chain case oil
Post by JRC ETD »
Ken is spot on.....no advantge with ATF, and you increase the liability failure potential If it was the hot set-up we would have put it in the chain cases from the factory 30 years ago. Hope it helps.....JRC ETD
JDFanPa
Chain case oil
Post by JDFanPa »
Its ok to mix some atf in but wouldnt just use it. The toyota dealership I work for we sometimes add atf into the 5 speed truck trannys to thin things as some of the older trucks can be a bear cold shifting.
Mr. Deere
Chain case oil
Post by Mr. Deere »
some one told me to use sae 40 or sae 50 I used 85-120 Or something in mine it was johndeere heavey equipment oil because my neighbor has a couple of tractors and i borrowed from him. .Easiest way to fill is to put sled on side trust me it will save you the cursing. and about an hour figuring out how to do it with it on the ground.
Bob
krazinite2003
Chain case oil
Post by krazinite2003 »
i use sae 30 in my 76 LF to put in in just screwed an air fitting into the chain case and put about a 6 inch peice of hose on to it then a bolt in the end of that , the air fitting is the tye that pushes into the hose then is held with a hose clamp it works great
yzboy99
Chain case oil
Post by yzboy99 »
So what is recommended? An SAE oil of some kind? 30 or heavier? Thanks for all the input!
cyclone crazy
Chain case oil
Post by cyclone crazy »
check the post under F.A.Q. - chaincase lube - this will answer your question.
yzboy99
Chain case oil
Post by yzboy99 »
Pretty dumb on my part. And i laugh at those who do the same thing......WATCH THE FAQ'S! Thanks for the info....
