in the market for dator pistons
S_Kyle
Real Name: Scott Kyle
Re: in the market for dator pistons
Post by S_Kyle »
I have herd of guys mostly for the Yamaha's using the next over size of ring and filing them x amount to fit the smaller piston. It could be an option for rings for the +.010 or +.030 pistons if they were made.
HoosierDeereMan
Real Name: Troy Miley
Post by HoosierDeereMan »
I don't know if this helps or not but a old parts catalog I have shows the early 70's Arctic Cat Lynx and Panther ran a 292 Kawasaki engine. The needle cage bearing used in that engine is a 19mm I.D. x 23mm O.D. x 24mm length.
Troy
Troy, Those are just about as hard to come by, a few years ago I was trying to get someone to send me a bad piston so I could compare it to a Dator piston & I can't even get the Kawi boys to turn loose of those.
sledder670
Post by sledder670 »
Ok so I am most likely going to have a batch of std. bore dator pistons made this year sometime. I am not sure when yet though. Is anyone inrested in complete kits gastkets crank seals everything to be sold as a package deal similar to wisecos top end kits with matched pistons? I am also intrested in doing the other race sled pistons as well I have a 295/S motor i can steal a piston from, but i dont have a 340/S motor. As of now they will be wiseco pistons but i still have a couple more people to talk to. With the crank seals i was only able to find a skidoo seal that was a single lip, if anyone knows where i can find a dual lip seal let me know. Thanks Brad Wheelock
Brad, Jerome can get the double liped seals.. Unless things have changed I believe you can only get Std, 0.020 & 0.040 over sized from Wiseco, Also I would Hope they are working off of a set of rings that will be available for years Because they also would fit other brands.. also if possible it would be nice to have those piston kits to include wrist pin bearings, wrist pins & piston pin clips..
I'm in for a couple of sets of each, 295/S, 340/S & 5 - Dator std. pistons. ( being I sent one std. Dator Piston to someone to look at & never got it back.. )
gumbofarmer
Post by gumbofarmer »
I need a pair of standard dator pistons and also a pair of .20 over. Please keep us posted if some are made!!!!!!!
I500
Real Name: Chuck Moser
Post by I500 »
How do i get in touch with Larry?..................... I will talk to him about standard pistons.
80spitfire
Real Name: Brian Kottke
Post by 80spitfire »
Larry's number is 701-261-8214.
-Brian
72' 500 Restored
74' 295/S Unrestored
75' 340/S Rider
76' Liquidator Restored
77' Liquifire Rider
80' Spitfire Restored
sledder670
he only has .20 and .40 over sizes left
I500
Post by I500 »
Thanks for Larrys phone info
Talked to Larry and he will check with Wiesco on minimum order and cost. We would be talking about standard pistons only. Please dont respond about 340/s or 295/s or any other type pistons at this time as this topic needs to stay focused. Bearings you may be on your own or perhaps a place like Hotrods would be an option. Pistons are not cheap so dont expect any clearance sales. No markup from me for the guys that commit to order and willing to prepay. If for some reason we cant fill the order than the rest might be financed by me and sold with heavy markup at latter date. <you play, you pay plan>.
Dont mean to step on anybodies toes here but if anybody has an alternative plan lets hear it and make a solid commitment. Dators are not cheap so dont expect these pistons to be. I believe the last order was $100 per piston.
Post here if your in or you can email me at comforthomes@frontiernet.net
Thank You
gumbofarmer
Count me in Chuck
skoalmint
Post by skoalmint »
Count me in for two sets at that price.Brock
80spitfire
Glad to hear that this is gonna happen!! I'm set for pistons though being as my Dator is at .40 over lol
-Brian
72' 500 Restored
75' 340/S Rider
77' Liquifire Rider
Chuck put me in for 5 pistons.. Somehow I ended up with a empty std Wiseco box, sure would like to know what happened to the piston that was in it?? :think:
sledder670
Wiseco has a min. order of 12 at 130 eachand price breaks at 12 24 50 100 . any one can have pistons made with a min order of 12
