Chain case gaskets for 340s
Anyone know a place to get chain case gaskets for 340s # M65697 and # M63228?
Thanks!
Thanks!
75 340s
73 JDX8
62 Polaris Snotraveler
69 Arctic Cat Panther
69 Johnson Skee hourse
70 Shi Doo TNT
80 Yamaha Enticer
73 JDX8
70 Shi Doo TNT
80 Yamaha Enticer
- Real Name: Ed Jones
Re: Chain case gaskets for 340s
I would be interested in a set or two of them to.
Nothing Runs Like A Deere
Last I knew Ed Poet had them. Deeredaze
I have a few M65697 gaskets. Email me at babs_4939@hotmail.com
In all honesty you can use other material or make your own.
Edit-
I just needed to take a deep breath.
Hey Jessie --- no offense meant. I only threw it out there for others if there were more needed that what you have available.
Randy
Randy
Thanks guys. Does anyone have the M63228??
75 340s
73 JDX8
70 Shi Doo TNT
80 Yamaha Enticer
73 JDX8
70 Shi Doo TNT
80 Yamaha Enticer
The M63228 or M63229 are used on virtually all the Deere sleds. Again, if Jessie doesn't have this, I have an M63228 available and have a few M63229 that are same except with square holes instead of round. It appears that many people have been using these interchangeably but others can chime in too if needed.
- M63229.JPG (18.62 KiB) Viewed 549 times
But in all honesty the NOS cork shrinks with time and does not fit. I even tried soaking one in water a few years ago without success. Not that hard to make if you have cork material.
In my experience the round holer's (M63228) are a bit larger in both OD and ID. The bolt circle diameter is a bit larger also.
alright, what do you guys do about gasket kit for the engine??
75 340s
73 JDX8
70 Shi Doo TNT
80 Yamaha Enticer
73 JDX8
70 Shi Doo TNT
80 Yamaha Enticer
