Flywheel Pullers
Re: Flywheel Pullers
Todd, which sachs motors used these. The old singles I have dealt with used kind of a bell shaped puller you threaded on the crank and then pressed against the crank end.
Scott Kyle,
Massey Whirlwind: 76 440 (2)
Mercury Hurricane 644: 72,73
OMC Snowcruiser: 66,68,70
Rupp: 70 34 Sprint
OTC Deere sled dyno
Rupp: 70 34 Sprint
OTC Deere sled dyno
Matt,
I was having the same problem...bolt heads too small, washers bending, etc. , but just yesterday I had special spacers made for the 6mm bolts that are thicker than washers (1/4"+), made from 4140, have a close tolerance fit to the bolt, and slide 1/2 inch into my puller slots (sort of a stepped washer)...it worked perfectly!
Robin
Robin
1972 Ski-Doo Olympique 300
1972 Arctic Cat 340 Cheetah
1974 JDX4
1976 340 Cyclone
1977 Ski-Doo 340E Olympique
1978 Kawasaki 440 Intriguer
1978 Kawasaki 440 Invader
1980 Porsche 924
1985 Ski-Doo Formula Plus
1987 Polaris Indy Sport
2002 Lincoln LS V8
Thank God for big garages...and tolerant wives!.
1974 JDX4
1976 340 Cyclone
1980 Porsche 924
2002 Lincoln LS V8
Scott I am guilty of typing before I am thinking again.
Yes, the bell threads on the the flywheel and the bolt presses on the crankend.
The big bolt I was thinking of is for pulling the clutches. I think it is 7/8".
