They've gone up a bit for the better quality puller.. But in no way shape or firm will a jaw puller work to pull a primary without major damage.
I have used them in stubborn secondary clutches, but very carefully not to bend the sheaves.
I use the grade 8 bolt and hyd fluid all the time.. Works great and is pretty safe, use Teflon tape on the threads and leave the fluid 1/2" from the top of the threads
Where is the clutch removal thread?
- SpitfireKing
Re: Where is the clutch removal thread?
Lowes and Home Depot are worthless when try to find bolts. I can never find anything at those places. I'll have to try a local business to see if they have some bolts that will fit.
Your local Farm Supply store will have grade 8 bolts as would most farm implement dealers.
as mention you can use a Grade 8 bolt easily purchased from Ace Hardware, Deere or IH or other Ag dealers, I use a impact deep socket that fits loosely in the hole as a spacer & still sometimes use fluid along with it, I use 80-90 gear lube as the fluid of choice, messy but won't slide by the threads as easy.. Also an impact wrench is usually a must. Sears now has 19.2 volt battery powered impact wrench for under $100.00 if you don't have a good air supply to run a air one..
I went and got about a 2 inch 9/16" x 18 bolt for about $3.50. Put some hydraulic fluid in the hole, Teflon tape around the screw, and a ratchet wrench. Was really easy to do. Barely even had to work. Really loud pop, though, when it came off. I probably only had the screw in a half inch when it popped off. I filled the hydraulic fluid pretty high, though.
Thanks for the help!!!
Glad you got it off without damaging the stationary sheave..
- SpitfireKing
IMO that's still the safest way to pull a clutch, even a correct puller can damage the inner threads and you back to hoping you can find to correct tap for it... That being said where I live I couldn't find that fine thread bolt anywhere but a specialty store and it was like $15 so not much less then a knock off puller
- Liquifried
Moto Source in Greenbay has them for $21.90
Fits all 102c and 108 clutches. Part # CP-1130
74 Evinrude Skimmer 400
82 Trailfire LX
82 Sportfire (Electric Start)
83 Sportfire (Original Owner)
83 Liquifire
84 Sportfire
97 Indy 500 Liquid
1996 Polaris XLT Touring
82 Trailfire LX
83 Liquifire
84 Sportfire
97 Indy 500 Liquid
