1980 LF - Parting Out (List Updated Feb 19th)
Re: 1980 LF - Parting Out
Does it have an electric starter and would it fit a 79 Trailfire?
Smiling everyday about my new-to-me 79 Trailfire...priceless!
Sorry no electric start.
I started tearing it apart tonight.
Has a good rear grab bar....$15 plus shipping
Engine Y pipe - $10 shipping
Eric A.
Jackshaft - sold
Stater - sold
Other parts:
radiator - $5
recoil (needs rebuild) - $10
straight handle bars - $5
track drive (good shape) - $25
overflow bottle - $5
Headlight Grill - $10.00 (nice shape)
Suspension is removed...
The front idler wheels in the center are missing.
Let me know what else you guys may need. If you think prices are out of line....make an offer!!
Thanks!
Stater - sold
Other parts:
radiator - $5
Thanks!
Eric A.
- SpitfireKing
I need the drag link if it's tight, can't seem to find local
What would you want with shipping to Manitoba Canada R0M 1P0
I dont think I can help you out there. The steering linkages are bent/messed up.
Thanks for the interest!
Eric A.
- SpitfireKing
Even the centre one? That one is solid steel and like 9/16 thick? They must have really nailed something
- jdrob
- Real Name: Rob
I do believe the 80/81 lf's had the aluminum rod instead of the steel it took them a couple years to figure out " hey maybe we should make those out of steel instead of soft aluminum ! I have only come across a few that weren't bent in all my parting out ! I can check and see if i have a steel one here ? It will prolly need the ends though ! lmkEven the centre one? That one is solid steel and like 9/16 thick? They must have really nailed something
Jdrob
- SpitfireKing
The steel one I have you can't replace the steering shaft end, only the one to the right spindle top
Mines an 80 too
Mines an 80 too
He needs the drag link guys, not the tie rod. Has anyone looked to see if a trailfire is the same? I know the steering shaft is a bit shorter....
DE
DE
Dustin Elder
Salem, OH
Salem, OH
- SpitfireKing
not the same...at least a 79's not..I tried but it's shorter and wrong size at one end..
- 80spitfire
- Real Name: Brian Kottke
Could I maybe see some pictures of the drivers and axle if they're still for sale? You could email pictures to playintopraise@hotmail.com if you want.
Brian
Brian
72' 500 Restored
74' 295/S Unrestored
75' 340/S Rider
76' Liquidator Restored
77' Liquifire Rider
80' Spitfire Restored
75' 340/S Rider
77' Liquifire Rider
you bet...they are a little more worn that I thought. Ill send a picture...make an offer!
Eric A.
Thanks JDSLEDS.com! Ive had some great interest in parts from this machine. I thought I would post an updated list of parts:
radiator - Sold
handle bars - $5.00
overflow bottle - $5.00
Rear grab bar - $15.00
exhaust Y pipe - $5.00
Headlight Grill - $5.00
front heat exchanger - Sold
spindles - $10.00
hood hinge - $5.00
gauges - Sold
cylinder heads $10.00 ea
speedo cable - $5.00
wiring harness - $10.00
carbs - $35
fuel pump - $15.00
If you are close to Waterloo IA...Id make a package deal for all the remaining parts. (then I dont have to ship)
Let me know if any interest in misc suspension parts.
I can get shipping quotes or pictures. Prices are not set in stone...so if you want to make an offer on several items...Just let me know!
On a side note...
The guy I bought the sled from said it was running great when he put it away. It just died on him. Well with a hole in the block and a piston skirt missing...i can see why it died. haha This may because the oil injection was removed....
radiator - Sold
handle bars - $5.00
spindles - $10.00
hood hinge - $5.00
gauges - Sold
carbs - $35
fuel pump - $15.00
On a side note...
Eric A.
Re: 1980 LF - Parting Out (List Updated Feb 12th)
do you have the complete temperature gauge system, thermostat..
if so would be interested in this parts, rear grab bar, hood hinge,wiring harness, overflow bottle. maybe y pipe.what would be the way to par you??
thank you
thank you
searsmonkey...
PM sent.
PM sent.
Eric A.
