78 CC Question
- JDXspec
- Real Name: Dustin
Re: 78 CC Question
Use the original front holes and move the rear holes back 2 3/4" (i will double ck that) as per my post earlier. It has worked out well so far
Re: 78 CC Question
I used a 1980 Liquifire rear suspension. I modified it by narrowing it by 1/4 inch to fit the AC track properly. The center rail distance of the AC track is 7-3/4 inch where as the JD rail center is 8 inch. Others are using the Liquifire suspension as is, but jdxspec and I have cut off the steel tabs that stick up against the inside of the track drive lugs. They were digging into the driveshaft drivers.jayson738 wrote:Now should i be looking for just an 80 skid? Will any 80+ liquifire skid work? Does anyone know what the new mounting locations would be for a 76 tunnel, in relation to the existing holes?
Jayson
