1979 Trailfire won't run
Re: 1979 Trailfire won't run
Well you can't really tell much from that picture. What was the difference between the two carbs?
Well I started at square one with the fuel system. Pulled the carb, pump and tank off the sled and cleaned everything out. I had flushed the tank in the past but when I started working on it again I didn't pull it I just drained the little bit that was in it. When I pulled it off and dumped it I think there was still some bad fuel sitting in the bottom of the tank, may have been a contributing factor. Choke was also to tight. Cleaned all the carb components. Cleaned the air box also. Put everything back on and fired it up. Seems to be working now. Motor runs good but now I think I have a clutching issue. I think its shifting to soon cuz it doesn't want to go mid speed to full. If you keep you speed up its fine but it's acceleration is lacking. I tried searching for some clutch info but I didn't really know what to search for. Is there an existing thread for this kind of issue? Thanks for the help everyone. All your comments moved me in the right direction.
