76 Cyclone help!!!!!
If you tested the stator correctly, the low speed is way off / bad causing your problems. Now for the bad news, finding a good used one or even a NOS stator. One of the member here send his off and had it reround but it is not cheap, around $200.00.
http://www.rmstator.com/en/index.php
Last edited by harleysportster on Tue Nov 25, 2008 11:23 pm, edited 1 time in total.
If Ed Poets is watching I think he has a few NOS stators....
Maybe JD Joe Raineville?
jasoniowa
Post by jasoniowa »
Does anyone have a picture of what this assembly looks like? I need a service manual bad.
My sleds, 1982 Liqufire, 1980 Trailfire, 1977 Sno*jet SST.
jasoniowa
Post by jasoniowa »
Queston: I have spark with the plugs out grounded to engine. Even if I pull the rope real slow I still have good spark. Does that still mean the stator is bad?
With a weak ignition, you can have spark 1 minute and not the next. An in-line spark tester is the only way to properly check for spark. A weak system may give you spark as you mentioned out in the open, but with the plugs installed and under compression the spark will fail.
This is what the tester looks like.
jasoniowa
Post by jasoniowa »
Do you also have a picture of what the stator looks like?
Here is picture of the electrical system.
