74 X8 spark
Danzig
Real Name: Paul File
74 X8 spark
Post by Danzig »
good luck!!
JDXsand00s
74 X8 spark
Post by JDXsand00s »
well i had to go to the backup engine now, tittl, you must have been right about the lean problem and we all know whay happens then. also my circlips on the piston broke and scored the jugs, to the only thing left good is the electrical and fan shroud. hopefully the backup i had will go good, it will be the first i have pressure tested to run over a mile, the one i blew wasn't either. i'll actually keep this engine under 30 mph and 6000 rpm for awhile and check the plugs ever mile or so. maybe i can actually do it right for once.
