75' JDX8
Rodimus Prime
75' JDX8
Post by Rodimus Prime »
Ok have to ask which spark system you have points or cdi? So far it sounds like bad connection around voltage regulator either bad ground(black) or not hooked in to voltage circuit (yellow).
Which type of voltage regulator do you have the little black box with single yellow wire or the aluminum box with a yellow and black wire? aluminum box btw that black wire should be grounded to frame.
jdsledwheelman
75' JDX8
Post by jdsledwheelman »
We went though the fuel pump on the carb and its good. But the pulse line dose act a little weak to me. How hard should it pulse :think: ? I'll clean the tank pickup, check compression, and put in new crank seals. I'm leaving on a U.P. trip on Sunday :beers; and I'll be back here on Thursday. So I'll work on it when I get back.
nick :cool:
72 500
73 600
74 295/s, JDX6
75 340/s, 400, JDX8
76 440 liquifire
77 440 cyclone spitfire
78 spitfire x2
79 spitfire
80 spitfire x3, liquifire x2, sportfire
81 spitfire
82 sprintfire, spitfire, 340 trailfire x2
83 snowfire
84 sprintfire, snowfire, trailfire lx
jdsledwheelman
75' JDX8
Rodimus Prime wrote:Ok have to ask which spark system you have points or cdi? So far it sounds like bad connection around voltage regulator either bad ground(black) or not hooked in to voltage circuit (yellow).
How do you tell if it has points or CDI :think: ? The regulater is the little black box with one yellow wire.
nick :eh:
72 500
73 600
74 295/s, JDX6
75 340/s, 400, JDX8
76 440 liquifire
78 spitfire x2
79 spitfire
81 spitfire
83 snowfire
Rodimus Prime
75' JDX8
cdi would have a ugly looking box near carb with wires going to the engine and coils. points is just nice wires to connecter and coils.
jdsledwheelman
75' JDX8
Rodimus Prime wrote:cdi would have a ugly looking box near carb with wires going to the engine and coils. points is just nice wires to connecter and coils.
I have a box on the firewall that says Presto-lite. It must be the CDI type. :?:
nick :think:
72 500
73 600
74 295/s, JDX6
75 340/s, 400, JDX8
76 440 liquifire
78 spitfire x2
79 spitfire
81 spitfire
83 snowfire
75' JDX8
Keep us posted Nick. Have fun on the UP.
