81 LF issue.
JDCornFlakes
Re: 81 LF issue.
Post by JDCornFlakes »
May I suggest trying the CDI to see if you can get it to start and run properly. Then once that mountain is crossed then start modding it.
You may have a sled that is running altogether differnt with milling heads and changing timing.
When drag racing cars you normally try 1 thing at a time...so you are sure what it did to improve or hurt car's performance. If change 7 things and car runs better maybe 4 helped and 3 hurt performance.
Also if sleds runs poorly then have to start looking to what is the issue from all changes, then start back tracking.
Just my little mind's thoughts....
Dave
DAVE
JDCornFlakes
Re: 81 LF issue.
Any resolution on this problematic Liquifire ?
DAVE
