I started on the engine resto yesterday and overall, I'd say this engine is in excellent condition and will make a nice powerplant for the Charity Sled! The "performance" side of me wanted to start porting the cylinders, raising compression, lightening the rotating assembly, etc. to make more power, but alas...I restrained myself and kept to the stock build montra instead...
This engine has been apart before however, and someone has replaced the PTO-side piston/rings at some point. They didn't even install new base/head gaskets either when they did it, as they just smeared silicone all over everything to seal it up. Hillbilly work for sure...
All the engine parts, including the PTO-side cylinder, is in excellent condition, so we're good there. Since the 'el cheapo replacement piston/ring set they used is different in weight and design from the original JD piston on the MAG-side, I think it best (for long term durability) to replace both pistons/ring sets with matching parts for re-assembly. Plus, we'll need an engine gasket/seal kit too.
Parts Needed:
- Two(2) Replacement Pistons/Ring Sets w/ circlips and pins
- One(1) Engine Gasket/Seal Kit
Enjoy the pics and more will come as I move along.
-pj
