LIQUIFIRE II
- Horicon Joe
- Real Name: Joe Wanie
Re: LIQUIFRE II
Here are two aluminum brackets I made. The one with the rubber isolators holds the silencer can and the other holds the coil.
Re: LIQUIFRE II
Deere's headlight was literally on top of the exhaust on the fire series, so they put that heat shield in to avoid melting the plastic bezel. The foam stuff still melted. If you've adjusted the light more forward since that picture you should be fine.
I would imagine similar circumstances during product development and your Swiss Cheese hood would be something they might have done to figure out where things needed to be on a production sled.
- Horicon Joe
Re: LIQUIFRE II
I'll bet they would not have used a hood with a 2x4 screwed to it
Re: LIQUIFRE II
I thought that might really screw up the drag coefficient unless you bevel cut the leading edge.Horicon Joe wrote:I'll bet they would not have used a hood with a 2x4 screwed to it
- Horicon Joe
Re: LIQUIFRE II
MILESTONE ……. OUT TO PAINT!
Here you can see the bent DOM tube reinforcement on both sides
- Horicon Joe
Re: LIQUIFRE II
Thought I would try my luck on custom seat made from the Doo seat. The rear storage would be nice ……
Have not decided if I am going to use it yet or not. Found a nice LED tail light the same size as the Deere footprint.
- Danzig
- Real Name: Paul File
Re: LIQUIFRE II
I like the seat idea
- Horicon Joe
Re: LIQUIFRE II
Thanks Paul ..... I have it set up that I can put either or on. We'll see how it looks with paint and decals?
- Danzig
Re: LIQUIFRE II
I can see an angled open gap where the seat meets the tank...
what did you do there ?
- Horicon Joe
Re: LIQUIFRE II
That gap made me give up on it 3 months ago and then the solution occurred to me ...... I'll show you guys later
- Danzig
Re: LIQUIFRE II
that kinda crap makes me wanna give up too...
Re: LIQUIFRE II
Hey Joe it looks awesome. Keep the pics coming. I can tell you r a engineer w mechanical skills, that is hard to find. most can tell u how it will work on paper but that is it ! where u can show us how it will work in the end. . Brock
- Horicon Joe
Re: LIQUIFRE II
Thanks Brock for the compliment...... I'll keep the pics coming
Cheers
Joe
Cheers
Joe
- Horicon Joe
Re: LIQUIFRE II
Let the fun begin! For any project like this, the fun starts when you get to put it all together!
Tunnel brackets and heat exchangers.
To rivet or to bolt? I thought long on this and went with all stainless button head socket cap screws and stainless nylocks. I figured if you need to take something apart it would be easier in case of a needed change. Also I wanted the stainless fasteners showing for the overall look I am going for.
Joe
Joe
- Horicon Joe
Re: LIQUIFRE II
You can see on the right heat exchanger that I had to add a long bent neck on it.
It was made to get me past the break assembly so I could attach a hose to it.
There was zero room to get a hose down there. The hose I attached to it was a small miracle in itself. Finding the right hose with the proper Z bend took me two weeks to find by going through auto parts stores inventories in the back room.
The steering column was put in for a final fit up before I welded the spline in on the neck. It then went out to be powder coated like the rest.
Joe
Joe
