John Deere Sprintfire 1983. Long time project....
- acesillini06
- Real Name: Matt Cappel
Re: John Deere Sprintfire 1983. Long time project....
I would call cometic to order the correct ones. C1020S
I will do thatacesillini06 wrote:I would call cometic to order the correct ones. C1020S
Sleds...
2xJOHN DEERE SPRINTFIRE 1983.
YAMAHA GP292b 1973
OCKELBO Trioman 1975
YAMAHA SRV 1982 (shrinked)
YAMAHA SRV 1990
YAMAHA SRV 1991
LYNX Rave 600ACE 2013
YAMAHA GP292b 1973
YAMAHA SRV 1990
YAMAHA SRV 1991
So now the project continue
The sled is in a garage at my work and lifted up on sled lift.
The Fuji/Polaris 440 has to come out
And out it is
With oil tank and gas tank out, it's time for some cleaning.
BEFORE
AFTER
And the decals removed. I don't know if I'm gonna get new ones or go for high polish
And out it is
BEFORE
AFTER
Sleds...
YAMAHA GP292b 1973
YAMAHA SRV 1990
YAMAHA SRV 1991
YAMAHA GP292b 1973
YAMAHA SRV 1990
YAMAHA SRV 1991
When having parts loose, got to clean them...
Oil tank cleaning outside and inside
It was not very dirty, but it made some difference
I really wonder how drunk the previous owner was when he cut the wires so short?
(sorry about the bad photo)
But nothing is impossible.
And the oil level sensor is like new again, working perfect.
Sleds...
YAMAHA GP292b 1973
YAMAHA SRV 1990
YAMAHA SRV 1991
YAMAHA GP292b 1973
YAMAHA SRV 1990
YAMAHA SRV 1991
Nice repair job Robert.
Thanks JDT!
Now when I have almost all parts and finally finished other projects and taking the time for the Sprintfire, I'm really all in to get it back on snow again
Yesterday I started with the motor.
Oily on the outside
Brake clean and cloth works fine
Not completely clean inside, but that's my own doing. I sprayed the crank and cylinder barrels with MoS2 oil when I got the parts home.
Clean
Last winter when I ordered some sled parts, I bought a oil seal to test if it would fit... and it fits perfect But I will have to get one more before I can put the motor back together. And the crank has to get new bearings too. SKF of course
Oily on the outside
Clean
Sleds...
YAMAHA GP292b 1973
YAMAHA SRV 1990
YAMAHA SRV 1991
YAMAHA GP292b 1973
YAMAHA SRV 1990
YAMAHA SRV 1991
Yup your deep into it now!
Was not too hard to change bearings on the crank.
Bearings off on both sides
Warming the new bearing a bit before pressing it on to the crank
A hydraulic press is just a big MUST
But always remember to fill the crank center before pressing, it's so easy the bend the crank otherwise
New SKF 6206 C3 mounted on the crank
Sleds...
YAMAHA GP292b 1973
YAMAHA SRV 1990
YAMAHA SRV 1991
YAMAHA GP292b 1973
YAMAHA SRV 1990
YAMAHA SRV 1991
Looks good but I have to ask. I noticed the bearing number on the box was 6202-2RS1. That part number looks to me to be a sealed bearing. Did you remove the seals from the new bearing?
Yes, I just popped out the seals. The RS bearings is the same as the open, but they are greased. It's not much grease and it will flush away with the gas running trough the crankhouse, it will give a little extra smoke in the beginning I had those bearing lying, so that's why I used them.nick80lf wrote:Looks good but I have to ask. I noticed the bearing number on the box was 6202-2RS1. That part number looks to me to be a sealed bearing. Did you remove the seals from the new bearing?
Sleds...
YAMAHA GP292b 1973
YAMAHA SRV 1990
YAMAHA SRV 1991
YAMAHA GP292b 1973
YAMAHA SRV 1990
YAMAHA SRV 1991
Today I made a good work cleaning the gas tank, inside and outside
After reading about how the plastic in JD:s gas tanks kind of loosen up in the material, I cleaned the inside with nuts and petrol.
Some strange fluid came out the first time....
The outside of the tank is very gray of plastic oxide
Gently using a hot air gun to warm out the softner in the plastic brings back the nice black to the outside again
And after the warm up, a polish with a plastic cleaner makes the tank look new again
DONE! And a new gas cap is ordered.
Sleds...
YAMAHA GP292b 1973
YAMAHA SRV 1990
YAMAHA SRV 1991
YAMAHA GP292b 1973
YAMAHA SRV 1990
YAMAHA SRV 1991
The tank will help make that thing look great!
Yes, bringing back the colors in the details makes the whole differens
Sleds...
YAMAHA GP292b 1973
YAMAHA SRV 1990
YAMAHA SRV 1991
YAMAHA GP292b 1973
YAMAHA SRV 1990
YAMAHA SRV 1991
Looks GREAT ! I have NOS oil sending units if you need one . All that heat makes me wander if it will work . Nice job ,keep the pics coming. Brock
Thanks skoalmint
Good to know if it should fail. But I don't think the heat will take it, the oil tank plastic has a lower melting temperature then the tin soldering.
Here comes some more pics
One of the first pictures of the sled in this thread you can se the strap over the seat, it's all green of moss...
I was planning to replace the strap with a seat belt from a car, but somehow I gave the old strap a few minutes of work
And with a good result
After a spinn in the washing machine it looks like new again.
Sleds...
YAMAHA GP292b 1973
YAMAHA SRV 1990
YAMAHA SRV 1991
YAMAHA GP292b 1973
YAMAHA SRV 1990
YAMAHA SRV 1991
