What I'm looking for is a couple of newer used 102C Comets, The newer style that use the LONG cover bolts ( these bolts are 1/4 X 1-3/4" long ) Not 3/4" long as the older 102C's are... Also the weights use harden bolts & not pins & roll Pins to hold them in.. Not worried about how they Look ( Clean or dirty ) Just so the faces aren't cracked. I also don't care if they come with a spring or not..
Wanted a couple of Good Comet 102C's For the Kioritz engines
Re: Wanted a couple of Good Comet 102C's For the Kioritz engines
never made myself that familiar with clutches what year would theyve changed styles ?
It looks what I need is 4, 80+ Liquifire & Sportfire clutches ( 102C's ) & I will also need at least 5 good used Stationary sheaves off the Cyclones or older Liquifires, ( Part # AM53942 )
Thanks for making me clarify this better..
Reason for this is I will be mounting these to a Cyclone engine & I have the tendency to over wrench the self locking cover screws ( 1/4 X 3/4 light weight self taping, self locking cover bolts )
