340 cyclone that has interment spark
davedude
Post by davedude »
i have a 340 cyclone that has interment spark on both side the stator check fine but i do not now how to check the cdi . The thing run but spark is in and out when you give it gas i have unpluged the waring harness and it still doses it i thinking it is the cdi any help thank
Re: 340 cyclone that has interment spark
You cannot test the CDI Box without the original type JD tester. Did you follow these guidelines?
http://www.jdsleds.com/community/viewto ... ?f=5&t=289
If all the tests check out, more than likely the CDI Box is bad.
davedude
Post by davedude »
thanks harleysportster that helps a lot :dance: :dance: :beers;
