76 Liquifire electrical issue
FireRider34
Post by FireRider34 »
Ok so my 340 has not power at all no tail light, no headlight nothing that uses power works so people, have said voltage reagulater, stator, the wirring beign wrong. I keep putting it off and know its time to fix it so what should I look for? how will i determine what it is? and is this common, all my questions have been answered by you guys and I realy appreciate it. I wish you all a merry Christmas aswell!
Re: 76 Liquifire electrical issue
The alternator windings are part of the stator. The voltage produced is above 15 volts and stepped down to 12 with the voltage regulator. Take a voltage reading (AC) at the wire connector terminal strip attached to the right side hood support. Test between the black and brown wires with the engine running.
12-15 volts AC = good alternator / voltage regulator
15 or more volts AC, good alternator, bad votage regulator
0 volts=-bad alternator windings
If you have the proper voltage at the black / brown wires but no lights, trace the wiring harness and also the connectors for a good ground.
Check / repalce the bulbs
FireRider34
Well i will check the voltage reading tomarrow and the bulbs are new, but what if it could be my wirring harnes was not installed properly by the previous owner that could be a mager factor aswell. So I think ill be spending some serious time in a my garage tomarrow going over a wirring diagram and then checking the readings, and does any one have a voltage regulater i could purchase? thanks for your all the help im only 14 and my dad works to much to help me, and I think this sled has so much potential and its a blast to ride newer sleds just are'nt the same joy again thanks for all the help.
FireRider34
Oh and a quick thought would uni air filters make any diffrence, i found them to make it easier to work on the sled and will it decrease power or increase it? Well again thanks for your help and merrry christmas
The carbs are jetted with the airbox. Unless you want to rejet, keep the airbox on. They can be tough getting back together. I tap the sides as I slide the top down on the bottom part and the metal plate aligns itself.
FireRider34 wrote:Well i will check the voltage reading tomarrow and the bulbs are new, but what if it could be my wirring harnes was not installed properly by the previous owner that could be a mager factor aswell. So I think ill be spending some serious time in a my garage tomarrow going over a wirring diagram and then checking the readings, and does any one have a voltage regulater i could purchase? thanks for your all the help im only 14 and my dad works to much to help me, and I think this sled has so much potential and its a blast to ride newer sleds just are'nt the same joy again thanks for all the help.
This voltage regulator should work but you will need to splice your style of correct terminal-ends on the wire.
http://cgi.ebay.com/ebaymotors/John-Dee ... ccessories
FireRider34
Well im just getting an idea for next year when im going to completely rebuild the sled but thanks man.
FireRider34
Yea I found a few so ill have to splice it and put the right conetion on.
