80 Liquifire is Dead! Rear Axle broken.
- Hackinator
Rear axle (m67952) broke while I was on the trail. Any solutions?
- IMG_4724.JPG (68.91 KiB) Viewed 358 times
Re: 80 Liquifire is Dead! Rear Axle broken.
finding another axle is an excellent solution.
- Hackinator
I used and aluminium welder and filled in both side and then ground it down to shape again.
If you want to strengthen it even further, drill mounting the bolt hole deeper past the repair, thread and get a longer bolt.
