The Little Powerhouse
Latest project.
Easiest clutch I've ever removed.
'72 400 engine 002.JPG (175.18 KiB) Viewed 3130 times
'72 400 engine 001.JPG (169.52 KiB) Viewed 3130 times
HoosierDeereMan
Real Name: Troy Miley
Re: The Little Powerhouse
Post by HoosierDeereMan »
Back to the basics huh? Single Walbro carburetor, points and condensers! Do you remember how to work on these? It's been dual Mikunis and Prestolite ignitions for the last couple of projects hasn't it?
Troy
Yup, this is out of the sled I rode as a kid. Pop bought the sled new.
Hasn't run since the mid 80's. It will be interesting to see how the engine has fared.
Here's a couple of shots of the internals. This is the first time this engine has been apart since some little Japanese gal put it together 40 years ago.
This engine has not run since the mid-80s, I had oiled it maybe 5 years ago. Nothing obviously wrong here, the pistons have very little visible wear, as do the cylinders. It appears that the engine had been running rich, judging by the carbon on the piston tops and domes of the heads, and the wash on the mag side. I believe the speedo says around 2500 miles on the sled.
I'll compare the ring gaps between the jugs on the engine, and an NOS one I have. That will give me a more precise measure of the wear.
Crank looks good so far, turns very smooth. We'll see what it looks like out of the case.
'72 400 engine 003.JPG (188.14 KiB) Viewed 2960 times
'72 400 engine 007.JPG (196.74 KiB) Viewed 2960 times
I have NOS pistons, a PTO side jug, and NOS gaskets, all bought from DK off ebay several years ago.
All I needed was a NOS mag side to complete a top end rebuild back to new specs.
I'd advertised here and there, I had a bunch of leads and the help of several list members here, but nothing had worked out. I had found one through an obsolete parts finder that one dealer wanted $175 for, and another $235.
I just couldn't pull the trigger on that, being as a PTO side jug had sold on ebay a few weeks ago for $20.
Then a list member found me one at a JD dealership. The box looks like it has been sitting on a shelf for 40 years...Oh wait, it may very well have done just that!
But the jug is well coated in cosmoline, and it appears to be in perfect condition!
The price was right, and this once again proves my contention that : ALL THE GOOD STUFF IS IN MICHIGAN! :lol22:
72 jug 004.JPG (194.58 KiB) Viewed 2820 times
72 jug 003.JPG (121.53 KiB) Viewed 2820 times
Damn Brian someone must like you..
A diamond in the rough there Brian. Congrats. :dance:
ICCSF 108 wrote:Damn Brian someone must like you..
Kenny, Kenny, Kenny everyone loves Brian!!!!!
Cabindweller
Real Name: Jerry Zebro
Post by Cabindweller »
Seeing a motor tore down never gets old for me thanks for posting the pictures.
Jerry
The case cleaned up pretty good. The top half soaked in parts cleaner over night, the bottom half I sprayed with solvent. The bottom has epoxy plugs that I don't want to disturb. This really didn't take the crud off, but it took the oil out of it, as it turned chalky after drying. Then I hit it with the soda blast, which really cleaned it up.
My soda blaster is a really cheap spot blaster. It is just a hand held suction sand blaster that I am running feed grade sodium bicarb through.
The crank is going to Jerome as soon as I can get it to the Post Office, as I decided that: "in for a penny...in for a pound."
I still have to get the base gaskets cleaned off the top half, they are really stuck on well, and the solvent and the blasting have not bothered them much. Looks like hand work.
72 340 case 003.JPG (167.66 KiB) Viewed 2638 times
Brian, They make a little high speed angle grinder & screw in sanding disks that are made to remove gaskets, they work great..
Such as
Ebay Item number: 280675110708, 2" 24 GRIT SANDING DISK FITS 3M ROLOC MATCO SNAP ON
Item number: 270703241732, 1 1/2" CONDITIONING DISK DREMEL ROLOC MANDREL SANDING
Item number: 160519383450, Ingersoll-Rand 301 Angle Air Die Grinder IR301
The crankshaft is back from Jerome, and the case has been re-assembled.
The pistons have been installed, and the jugs dropped on. Progress is slow...but it is progress.
Below: a genuine JD piston pin tool in use.
72 engine 001.JPG (191.14 KiB) Viewed 2559 times
Still going together.
72 engine 005.JPG (186.63 KiB) Viewed 2503 times
Nice and tiddy Brian. Looking fine. :beers;
One of the unsolved issues I've been sitting on was how to get the inside bearing off the engine fan shaft.
The book says slide it off...well it wasn't coming!
In my opinion, the later outboard mounted fan design is much easier to work on, the shaft can be tapped or pressed out of the fan tower without issue. Here, the shaft is pressed onto the fan, and the inboard bearing sits down in a recess, so there is no easy way to pull it off.
I felt that my bearing separator tool was my best bet, but I had to give it something to bite on.
I ran a short bead of weld on opposite sides of the bearing, tightened the separator on the bearing, then installed my harmonic balancer puller. As I turned the bolt of the puller I heard a crack, then the puller went loose.
Thought I had won, but inspection revealed that the outer race had broke a chunk out of it, no movement of the bearing. The broken area was big enough that it allowed me to cut the ball cage with a small chisel, then pop the balls out one by one. Once the balls were out, the outer race lifted off, leaving the stubborn little inner race.
The bearing separator was now clamped into the groove in the inner race, and it then finally gave in to the persuasion of the puller! :beers;
I love it when a plan comes together!
Had a similar situation the night before while pulling apart the rear idler shaft on the 400. The bearings had to be pulled the same way, then the plastic wheels had to be pressed off. After all that, I realized that the good looking shaft had a 1/4" bend in the middle! :wall:
