wiseco 440/5 pistons
lwb140
Real Name: Wade bennett
Post by lwb140 »
anyone know if wiseco made pistons for the 440/5 mills ,have a part number? also looking for oversized pistons for the same ,thanks wade
Re: wiseco 440/5 pistons
Wade, They did for the 440/3 & 4's my books don't even mention the 440/5..
KamJD600
Real Name: kameron peck
Post by KamJD600 »
i had the same problem last winter!!! wiseco does not make a piston for the 440/5 But they makes a single ring pisten for a TNT that will fit after you clearence them for the crank. the only problem you will have to have a thicker head gasket made for it to lower compression or you will have over 200 lb of compression like i did...
if your intrested i can try and find the numbers for them this weeknd if you intrested...
Kameron :winter:
200 PSI in a 440/5??
Cool!!
I m likin' that.
A tank of high octane and Go- baby, Go!
The KEC400/2 ran over 200 lbs stock used in the 71 Scorpion Stinger.
S_Kyle
Real Name: Scott Kyle
Post by S_Kyle »
That kind of compression might be a bit hard on the shoulder pulling over.
Scott Kyle,
Massey Whirlwind: 76 440 (2)
Mercury Hurricane 644: 72,73
OMC Snowcruiser: 66,68,70
Rupp: 70 34 Sprint
OTC Deere sled dyno
Not that bad at all really.
I once pulled over a 71 TNT with the 775 twin with 230 lbs.
That was nasty!
The Scorps( I have three of them) pull easy with two hands.
KamJD600
Post by KamJD600 »
it was real fast when it wasnt pinging
I think any engine with over 150 psi needs premium.
