'80 Liquifire Bearings
JD600
Post by JD600 »
Hi guys.
As most of you guys know, I'm primarily a midmount guy, but this fall i aquired a clean '80 Liquifire. I just plan on making a rider out of this one, so it is just going to get a good mechanical restoration, nothing cosmetic. My question to you all, does anyone know the I.D. of the jackshaft and drive shaft bearings? I knwo they are self aligning type bearings. I know i could tear mine apart and measure them, but i'd like to have all of the parts here when i pull it in as i don't want it sitting in the shop very long. NBPS (New Breed Parts Store) has all of the bearings i need, i'm just not sure on the quantity as Deere does not list the dimensions in the parts catolog. Thanks for any and all help.
DE
Dustin Elder
Salem, OH
lwb140
Real Name: Wade bennett
Re: '80 Liquifire Bearings
Post by lwb140 »
i believe the id of the jackshaft bearings are 7/8 and the drive shaft are 1 inch the od is the same for both it takes two of each size unless you are running an ac jackshaft for a 1 inch secondary then it takes 3 one inch and 1, 7/8 [ a tip for your racer ] wade
JD600
Post by JD600 »
lwb140 wrote:i believe the id of the jackshaft bearings are 7/8 and the drive shaft are 1 inch the od is the same for both it takes two of each size unless you are running an ac jackshaft for a 1 inch secondary then it takes 3 one inch and 1, 7/8 [ a tip for your racer ] wade
Thanks Wade. I'll get them ordered. Did you ever figure out what your jackshaft was from? I have a primary that needs attention, and no secondary yet. So for now, its going to sport a 102-c.
DE
Dustin Elder
Salem, OH
lwb140
Post by lwb140 »
not exactly like an early eightys panther they are 23 inches long and seem to be a direct bolt-it from the 340/s through 80 l/f at least . the late eightys eltigre had a 25 1/2 incher which are just too long , ive got a line on a couple more if you need one wade
JD600
Post by JD600 »
I'll need at least one of them. Just put it on my tab. :letitsnow:
Dustin Elder
Salem, OH
lwb140
Post by lwb140 »
on order , oh ya i suggest the cat disk as well , it has the 1/4 inh key instead of the 3/16 of the deere , thety are much stouter , they are larger diameter but i know a guy that can fix that wade
JD600
Post by JD600 »
I actually have a few Liquidator brake disks i was going to use, but that might be better....
DE
Dustin Elder
Salem, OH
Sprailfire340
Post by Sprailfire340 »
:shock:
:sled: ME
lwb140
Post by lwb140 »
JD600 wrote:I actually have a few Liquidator brake disks i was going to use, but that might be better....
DE
dator ones are 3/16 key to rebroach or deal with otherwise work great wade
Hackinator
Post by Hackinator »
