Liquifire carbs
Liquifire carbs
Has anyone messed around with putting non powerjet carbs on a newer liquifire? Maybe it wouldnt work the best I'm just thinking.
- Liquifire84
Re: Liquifire carbs
I have and its worked out pretty good. I have the set up on one of my 83's. I also really worked the clutches to so I could get the most out of the carb changes. I still like the pj's they do have a bit more midrange which is where the pj's help.
Brice
Brice
- hotrodcr250
Re: Liquifire carbs
what did you end up for jetting ?,what size carbs you use? airbox or no airbox?what all did you do with the clutching ?-thanks chrisLiquifire84 wrote:I have and its worked out pretty good. I have the set up on one of my 83's. I also really worked the clutches to so I could get the most out of the carb changes. I still like the pj's they do have a bit more midrange which is where the pj's help.
Brice
- Liquifire84
Re: Liquifire carbs
I will have to dig it out. With no snow here I havent pulled my machines out yet. I dont have an air box on it but put the uni pods on it. I have a polaris primary on it. I should be home this weekend and I can pull it out and let you know.
Brice
Brice
