Spitfire wiring block terminal
deerehunter
Post by deerehunter »
Could someone take a picture of the 78 Spitfire wiring block terminal and post it here. I need to see a terminal with NO wires hooked to it. I need to know what is connected to the 4 double terminals,the description on the terminal. I do not have a terminal to look at. Thank you.
Re: Spitfire wiring block terminal
I can't help you with a picture but have you seen the wiring diagram.
http://www.jdsleds.com/tech/wiring/70spitfirewiring.jpg
deerehunter
Thank you.
