1972 - 400 questions
rtraut1964
Post by rtraut1964 »
1. What type of seat cover was on the original ? smooth or pleated
2. Did the original skis have shocks ?
3. Was the original grab bar on the back black or chrome ?
Thank you
Re: 1972 - 400 questions
Not sure about the seat, but I think it was pleated? (Guys let me know if I am full of it...)
Ski's did not have shocks.
The 72 400 grab bar was black, the 500 was chrome.
I hope this helps,
80spitfire
Real Name: Brian Kottke
Post by 80spitfire »
Rainville is correct. The seat isn't like a sewn in pleat though it's more of a molded pleat. But still a pleat nonetheless!
-Brian
72' 500 Restored
74' 295/S Unrestored
75' 340/S Rider
76' Liquidator Restored
77' Liquifire Rider
80' Spitfire Restored
JD600
Post by JD600 »
All Deere seats were a one-piece vacuum formed seat. the 72's did have a pattern in the top portion of the seat though.
DE
Dustin Elder
Salem, OH
Hi Guys,
Thanks for adding info about the seat. One thing Dustin, the 73 JDX-4 had a flat, stitched seat from the factory. And if memory serves me right, early Tralifire seats had stitched seats that were otherwise smooth.
The 73 X4 and the 300s had the smooth stitched seam seat. No hump at the rear, and the cover was not bonded to the foam.
The 72 seat appears the same as the rest with the hump at the rear, it had the molded-in lines across the seat.
However, the 72 seat is unique in that it has a smaller opening at the rear for the unique 72 tail light, and the 72 didn't use clips at the front to retain the seat. The 72 seat is held on by 1/4" screws, two in front, two in back.
JD600
Post by JD600 »
Thanks for the corrections guys. i forgot about those little steel tunnel abortions, and i haven't aquired the 300 to complete the '75 set yet. its the only one i'm missing....
DE
Dustin Elder
Salem, OH
rtraut1964
Thanks for the information
Is it possible to find or have an original seat cover made ?
estimated cost for a cover ?
Looking for a good kill switch cover & light switch cover ( Rubber covers )
Any relation to the Traut Bros from Motley?
rtraut1964
Not sure, Most of the relation is in the St. Cloud, MN area. One never knows
