invader twin pipes
sledneck5454
invader twin pipes
Will the kawi invader twins work on my 83 liquifire? if so what jetting and clutch combo is good. Thanks sled
That Girl Racing
- Real Name: Peter
Re: invader twin pipes
They will make the sled way harder to put in the back of a pickup!
sledneck5454
Let me rephrase that will aaen twin pipes from a Kawasaki invader fit the liquifire haha
That Girl Racing
- Real Name: Peter
That is a different deal. The answer is yes and no. Those pipes are designed to run around 9000 RPM. Your motor is not. The exhaust port is to low and the intake does not have enough duration. You can call Aaen and they will give you the porting and jetting recommendations for the pipe. If installed without modifications the sled will be slower than stock. Peter
sledneck5454
Thank you for the info. I called Aaen today and he was out of the shop. I will call again tomorrow thanks again.
sledder670
good to know i bought a set this summer. Could you share the info you get with me. I also have a set of stock twins for a kawi as well big paper wieghts if anyone is intrested.
Invader440
Here's the info from the installation Instructions:
Move top of exhaust port up to 30mm from top of cylinder and widen it 1mm on each side. Make sure to hang adequate radiuses in corners and good chamfer on edges.
Move bottom of intake port down to 25mm from bottom of cylinder skirt.
Head: Machine 1mm off gasket area and squish area to improve compression. Clearance between piston and squish area should not be less than .075".
Carbs: with stock carb and gutted air box, the jetting should be changed to a 135-145 powerjet and a 160-180 main jet depending on local conditions. Start on the rich side to prevent seizure.
Best results were without the air box using a 38mm carb with no power jet. Jetting for 38mm carb is: 360 main jet, 35 pilot, 6DH3 needle, Q2 needle jet, 2.5 slide, no air jet.
Use premium 84 octane gas or octane booster with regular gas.
