Just talked to the guy building the crank for my 76 Cyclone about the inner seals for it. He told me the 10mm seals are next to impossible to find, so he was going to use 8mm ones. Now he can't find the 8's so he is going to build it with 7mm inner seals. He called to ask me about this but decided it shouldn't be a problem if I get the seals in the (grooves ?) of the case half so they don't move.
This guy has been building cranks for years and he is the go to guy in our area, trusted by everyone. But does anyone have any other input on this?
Thanks Adam
340/22? Inner crankcase seals
Adam Epp
Winnipeg, MB, Canada
74 400 (2 - sold)
74 400 (2 - sold)
- Sprailfire340
Re: 340/22? Inner crankcase seals
Pardon me for my confusion, but you talking about the seals on the end of the crank? No doubt Matt can get source them too.
MAG - http://www.mfgsupply.com/501301.html
PTO - http://www.mfgsupply.com/501302.html
Any other questions regarding cranks I would call Jerome directly asap. He's been rebuilding JD cranks for years.
Crankshaft Services - 320-267-8801
Hard to get on the horn, but he answers texts pretty quickly.
ME
nope, I'm talking about the center 2 seals, as in splitting the crank to change them, sorry for the confusion. This guy I use is one of the best and I trust his judgement, just wondering if anyone has come across a situation like this.
thanks, Adam
thanks, Adam
Adam Epp
74 400 (2 - sold)
74 400 (2 - sold)
Wouldn't the center seals be the same ID as the outter ones??
Do you know the other dimensions of the inner seals? The standard 1302R are 30mm ID x 62mm OD x 10mm wide with a rib. I would assume they would be the same too.
