Hi
Got my 600 dug out and running good in the shed.
Motor was redone 2 years ago and sled was parked.
Starts good (primer kit installed) Sits and idles real nice. Get on and go for a ride runs great till you let off the throttle. Then it bogs like crazy. I have to feather and play with the throttle to get it to move. Once you actually get it going it runs good till you let off the throttle and bog situation repeats.
It has a Bendix carb. I have played with the idle and high speed screws. just when I think it is some better, it starts all over.
I don't have much experience with the Bendix carb.
Looking for sugestions..
Lloyd
JD 600 issues
- Real Name: Lloyd
JD 600 issues
Several Deere's
Several Kawasaki's
ACSCC #1534
Several Kawasaki's
ACSCC #1534
Re: JD 600 issues
Could be an over fuelling issue?
What works good on those machines with no alterations is a good rebuilt Walbro carb
Adam Epp
Winnipeg, MB, Canada
74 400 (2 - sold)
74 400 (2 - sold)
Re: JD 600 issues
One thing you would need is a dual outlet fitting to go in the gas tank.
Re: JD 600 issues
Lloyd, have you tried just running the idle higher?
- Real Name: Lloyd
Re: JD 600 issues
Hey Matt
Yes I have, it did not seem to make much difference.
Would a leaky needle and seat cause this problem?
Several Deere's
Several Kawasaki's
ACSCC #1534
Several Kawasaki's
ACSCC #1534
- Real Name: Les
Re: JD 600 issues
Have seen the check vavles for the primers stick and when you let off the throttle it will draw fuel through the primer lines.
