No fire at plugs
liquifire
No fire at plugs
Post by liquifire »
HI Guys,I,am having trouble getting spark at the plugs.I have a new cdi,ignition coils,caps and plugs.I also installed a new stator and timing ring.Could the problem be with the flywheel.I know the capacitors are charging but the scr switches are not opening.I have removed the lighting circuit and kill circuit to help close in on the problem.I checked the magnet on the pulse puck,but not sure how strong it is or should be.I also noticed that the magnet is exposed on either side of the gear tooth.About and inch .Is this normal ? THe sled is a 1978 liquifire 440. It seems like the cdi is not getting the pulse.Please help if you can.
Re: No fire at plugs
Check this out and follow the guide lines.
http://www.jdsleds.com/community/viewto ... ?f=5&t=289
Viktory2k1
Post by Viktory2k1 »
Never heard of the magnets sticking out an inch. I must follow this topic. Maybe something is not wired right between stator and CDI?
Like a short?
Current:
77 John Deere Cyclone 440
98 Yamaha SRX700
Past:
1968 Rupp GT300
1970 Evenrude Bobcat 440
1976 Arctic Cat Cheetah 440
1976 Ski-Doo TN'T Everest 440
1978 Yamaha Exciter 440
1979? Yamaha Enticer 300
1979? Yamaha Enticer 250
1987 Polaris Sprint 340
A photo of that flywheel would help.
