Hey guys, i went to the tech pages to find a spark plug replacement for my 400. I was surprised at the fact that the 1972 400s are broken into three groups?! My serial number is in the first group but i cannot find any of those listed plugs in my local shop. Why are they different? Why does the last group of sleds take a standard br9es but mine takes a plug i can't seem to find? Can i use a br9es in my machine?
Recoil
72jd 400 spark plug question
Re: 72jd 400 spark plug question
The 400's used 3 different engines over their 6 year production run (340/4, 340/5, and 340/22 Reed) The reed engines had much different cylinder heads than the piston ported engines, thus the different reach spark plugs. I'm surprised that your local shop does not have a cross reference book, as they should be able to cross the old numbers even though they are no longer available. That being said, i believe you need BR9HS plugs, but i will need to consult the manual as my memory leads me astray sometimes.
DE
DE
Dustin Elder
Salem, OH
Salem, OH
So i take it that is just a shorter reach plug? Well i hope these old plugs hold up during my vintage run tomorrow! If you happen to find out please let me know. I would certainly appreciate it.
Recoil
Recoil
Found this in the FAQ section.
http://www.jdsleds.com/community/viewto ... f=4&t=2077
Thanks Pat. I was looking for that last night, but i couldn't find it. As i recall, the heat range of the stock plugs falls somewhere in between a BR9 and a BR8, the BR8 being the hotter of the 2. Either one should work just fine.
DE
DE
Dustin Elder
Salem, OH
Salem, OH
The 72 and 73s all take the short reach plugs. I have been running the B8s for the past seven years, so far that heat range seems to be working out OK.Recoil wrote:So i take it that is just a shorter reach plug? Well i hope these old plugs hold up during my vintage run tomorrow! If you happen to find out please let me know. I would certainly appreciate it.
Recoil
